[Ri...] Posted September 16 Share Posted September 16 I have always struggled with restricting clearance planes. On our two Micuras, we have minimal space for Probe and styli changes. Every part axis lays in the X axis; all probes change in the +Y axis (To and from the rack). I want to add more clutter to the CMM, most likely a Stylus cleaner, from this I want to force all stylus changes that use -X and +X to always go over the top of the fixturing/Parts. All of my Styli are either -Z or -X and +X. I do not want any probe travel in the -Y axis based on the Base Alignment. Any help is appreciated. Link to comment Share on other sites More sharing options...
[Ri...] Posted September 16 Author Share Posted September 16 (edited) Screen shot of Micura setup. There is just enough room at the Probe rack for the Sensor to pickup/Drop off probes. Edited September 16 Link to comment Share on other sites More sharing options...
[Da...] Posted September 16 Share Posted September 16 Very interested in an answer to this We have some fixtures that are almost tall enough to interfere with a Y move going to the MSR. It already uses the height of the lowest rack position when returning. I seem to remember a long long time ago , a calibration tech changed an old contura to a Z max position. but, I'm not sure how he did it. ( rack approach parameters? maybe?) Link to comment Share on other sites More sharing options...
[Ma...] Posted September 16 Share Posted September 16 In the Approach Parameters you can set it to move +Z to a specific height before and after a stylus change. Here I have this system going up 300mm in +Z before it stores and also after it loads. This clears any fixtured parts we have and avoids a direct line to the rack. Not sure if this is what you are looking for. Link to comment Share on other sites More sharing options...
[Ri...] Posted September 17 Author Share Posted September 17 Mark Distefano, I have set approach parameters, now I want the clearance plane to always be +Z when running programs. Link to comment Share on other sites More sharing options...
[Ju...] Posted September 17 Share Posted September 17 Have you tried Plan>Navigation>Block Edges and checking the boxes around the sides? 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted September 17 Author Share Posted September 17 Please sign in to view this quote. Poor choice of words on my part, I did mean I have trouble with blocked edges. I can never seem to get it to do what I want. I am hoping others have blocked edges to force a program to move in the +Z clearance plane all the time and could guide me on proper settings. Link to comment Share on other sites More sharing options...
[Ri...] Posted September 17 Author Share Posted September 17 Attached is a SAB model of the Micura setup. (In ZIP format). model.zip Link to comment Share on other sites More sharing options...
[Ri...] Posted September 17 Author Share Posted September 17 SSC files. (Odd, the SSC files have more data than the entire CMM with a probe rack). Micura SSC.zip Link to comment Share on other sites More sharing options...
