Lost X,Y,Z position of all RDS probes and cant requalify them.
Found a mildly infuriating problem.
Running simulation and all the sudden all my RDS probes acquired odd values in the X, Y and Z positions.  It started visually showing the stylus and head something like 6 inches off the part, but still gives good nominal  feature values after simulation.
I try to requalify my probe.  First, it says that I cant do it because its going to shank out on the reference sphere or its at the wrong angle.  Wierd because Ive been simulating the same probe for years.  So I grab the master probe, set the reference sphere location, then try again and it works.
But now I have completely different XYZ values that dont make any sense.  I hit requalify again, it does its 12 angles, and then a completely different result:
image.png.9556104b8a6a29607a1ae93470d58cea.pngimage.png.3d43e90b91a5a442cb343a2de7d6cf1c.pngimage.png.917e75681baec1b1765dc842255e14df.png
Same probe 3 times in a row.  Not entirely arbitrary because 5.232 seems to be repeating in various places.
Any thoughts?
Posted (edited)
I think I got just about everything relevent in there.  If I hit the qualify stylus button, then all the numbers change.
Edit: I do have a work around for now.  If I delete all the rds systems from the management, and reimport the ssc file, the fresh probe work.  But if I hit the qualify then the problem comes back.  Also it didnt affect any of the fixed 5 point stars, only rds probes.
What does your RDSCAA MasterProbe information show?
This is mine for a standard RDSCAA MasterProbe and TL3 Sensor.
Also shown is my MasterProbe after qualification for Planner.
Looks pretty simular to yours.
The master probe I use looks a bit different since it is not qualified as an RDSCAA.  I wasnt actually aware that you could do that even - Is there a reason/benefit to it?
I do not know if there is a benefit.
When I imported it, I selected RDS CAA.
What I do notice is your X and Z are both 0.0000.
