[To...] Posted October 2, 2025 Share Posted October 2, 2025 I am attempting to scan a check fixture for its annual calibration but when I import the CAD it has the check fixture with the CAD for the part on it as well. Is there a way to delete CAD features in Zeiss Inspect 2023? Link to comment Share on other sites More sharing options...
[Ma...] Posted October 2, 2025 Share Posted October 2, 2025 I am not sure if this can be done on 2023, but you can click little pen icon next to model visibility checkbox - edit mode - there you can edit objects. Link to comment Share on other sites More sharing options...
[An...] Posted October 5, 2025 Share Posted October 5, 2025 It may help to drag and drop the file containing the CAD data into INSPECT and first import it into the clipboard. There, the CAD data for the component can be easily deleted if necessary. Only then should you proceed with the actual import into a component, which would then only be the component capture. 1 1 Link to comment Share on other sites More sharing options...
