[Ja...] Posted October 8, 2025 Share Posted October 8, 2025 I have a Duramax and this morning the computer didn't start up properly. I got a blue screen. I had to restart it. After that I had lost my machine tab. I followed the solution to that is posted in the Zeiss portal. I think I lost all my probe data though. Can anyone guide me through how to try and get that back? Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/ Share on other sites More sharing options...
[Ri...] Posted October 8, 2025 Share Posted October 8, 2025 Unless you have a backup copy of the config folder, I think it's safe to assume that it is gone. Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-139723 Share on other sites More sharing options...
[Ja...] Posted October 8, 2025 Author Share Posted October 8, 2025 I got it figured out. Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-139727 Share on other sites More sharing options...
[Ri...] Posted October 8, 2025 Share Posted October 8, 2025 Please post what you did to get the probe data back so others may be able to save their data. Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-139731 Share on other sites More sharing options...
[Cl...] Posted October 8, 2025 Share Posted October 8, 2025 Doesn't your IT perform daily real-time back-ups? Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-139739 Share on other sites More sharing options...
[Ma...] Posted October 8, 2025 Share Posted October 8, 2025 I am quite busy, but i am working on a program to keep changes on those files and let you manage versions. Hopefully i'll manage some time for that and optimize utilization of cpu ( quite demanding, triggers are not plausible ) 1 Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-139747 Share on other sites More sharing options...
[Ja...] Posted October 8, 2025 Author Share Posted October 8, 2025 Please sign in to view this quote. I followed these instruction on what to do when the machine tab is lost, https://portal.zeiss.com/knowledge-base?id=483015 When I typed in the name of the new tab I typed "Duramx" instead of "Duramax". I corrected that and it worked. My only problem now is I get a message asking me if I really want to connect two controllers when I turn things on. I select no and things work fine. I deleted the "Duramx" tab but I think still get the message. It's a really bad day for this to happen. I don't have time to work on it. Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-139753 Share on other sites More sharing options...
[Ke...] Posted October 8, 2025 Share Posted October 8, 2025 With any luck it just defaulted the Simulation (or one of the other machine tabs) to connect at system start, if you go to the Extras-Settings-CMM, go through the machine tabs and see if the "Reconnect during system start" checkbox is checked on any of the other tabs. If so, uncheck it and that should stop happening Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-139755 Share on other sites More sharing options...
[Ja...] Posted October 8, 2025 Author Share Posted October 8, 2025 Please sign in to view this quote. You are exactly right. I believe you just helped me get rid of that message too. 1 Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-139757 Share on other sites More sharing options...
[No...] Posted October 9, 2025 Share Posted October 9, 2025 I strongly recommend to use the Calypso backup function on a regular basis (alternatively backup the whole config folder). Since the problem with stylus database access has been eliminated, it's quite useful. 2 Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-139781 Share on other sites More sharing options...
[Ky...] Posted October 9, 2025 Share Posted October 9, 2025 It behooves me to mention that the computers that ZEISS supplies (at least in North America) have a restore software called "Acronis" installed. By default, it is configured to create a backup every week (I think at like Saturday at some early hour). Of course, if you have multiple shifts, it might not work as the data is being used, but you can use that as a backup to restore the config as well. Has gotten me out of more than a few jams. You can read more here: https://portal.zeiss.com/knowledge-base?query=Acronis 2 Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-139899 Share on other sites More sharing options...
[Ja...] Posted December 5, 2025 Share Posted December 5, 2025 Arrived this morning to find a similar issue with our O-inspect 543... inspectors mentioned issues with the CMM and I found that it was starting a new connection with the SIMULATION configuration and the O-Inspect configuration was nowhere to be found. Checked Acronis first as Please sign in to view this username. suggested and found last backup from.. ~2020.. about when we received the machine so that must have been disabled... Thankfully, using the thread Please sign in to view this username. suggested, https://portal.zeiss.com/knowledge-base?id=483015, I was able to simply add the "O-Inspect" config back as the folder was still present on the computer and everything *appeared* to be restored. It will be a mystery as to what caused this, I can only speculate that someone was tinkering around with what they shouldn't (Or IT?) however I should note though that the C drive was also full... (I am still not sure how/am working that one out) so maybe that was the most likely cause. I went and cleared some low-hanging fruit of data that could be deleted ~about 40gb worth so no longer at capacity. I was receiving some calypso messages about no room on the drive before this. After doing this- I was still finding issues as the automatic stylus changer was working but I was getting this error message in the console: I was able to find what I believe was the fix below by manually loading every stylus we use from the racks manually and then using the Teach ID in the stylus system management. After doing so the automatic stylus changer now works and I do not get the error message anymore. I had a console output for each line assigning the stylus ID. Afterwards I was able to run a program that utilized multiple styli again without issue, so I believe my problem is resolved. Thank you all above for the thread. I hope the Teach ID was valid to do and isn't bad advice. Time to figure out why ACRONIS was backing up. 🙂 Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-143113 Share on other sites More sharing options...
[Ja...] Posted December 5, 2025 Share Posted December 5, 2025 Yeah, Please sign in to view this username. , ACRONIS definitely is not backing up regularly on our O-inspect or our Contura, each only has a backup from the first install + two more shortly after. When I use the ACRONIS help pages in the knowledge base it states to use the "Acronis Cyber Backup" program, but both of ours for example only have the "Acronis Cyber Protect Monitor" which opens up a small window with not much to do stating there is no scheduled backup. Curious if it is just an older version.. if you try to follow anything it leads you to a "Cyper Protect Web Console" that we don't have login details for. I tried playing around for a bit but it is a bit more work than its worth for now and will look into it in the future. We also just had a Duramax install and we never heard anything about Acronis so if there is any old or new additional literature outside of the knowledge base that would be helpful, although for our 2022 Contura Install I was around for it was similarly not mentioned and I have always wondered what Acronis was on the PC. Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-143117 Share on other sites More sharing options...
[Ky...] Posted December 8, 2025 Share Posted December 8, 2025 Please sign in to view this username. To my knowledge Acronis has always been set up to backup weekly, at least on the machines we send out. It is configurable, though, so perhaps in the intervening time someone turned it off (IT or something because they were concerned about the backup for some reason). I unfortunately don't have a lot of experience with the Acronis program on the computer itself (it's not on the computers we give to techs or AEs). There should just be a shortcut labelled "Acronis Backup" or something similar on the desktop. There is a password screen, but you should be able to just hit okay through it to my recollection. Do you have an Acronis folder on your D drive? I can't tell for certain, but is it a computer from us and when would you have gotten it? I think we only started giving Acronis around 2020, so its hard to tell. Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-143175 Share on other sites More sharing options...
[Ja...] Posted December 10, 2025 Share Posted December 10, 2025 Both Machines came from Zeiss yes, they also both have the separate drive and the files like screenshot below, I am not sure what exactly has stopped it though, likely IT. No Acronis file on the desktop and again... all we seem to have on both computers is this cyber protect monitor that doesn't seem to like doing much of anything. Please sign in to view this username. I appreciate your response. I'll poke around with it myself more /one day/. Link to comment https://qualityforum.zeiss.com/topic/24695-lost-probe-data/#findComment-143333 Share on other sites More sharing options...
