[La...] Posted October 8, 2025 Share Posted October 8, 2025 (edited) I want to understand formula, result elements, etc. better and I was wondering, is there any forum or documentation that goes over the Calypso PCM language? Edited October 8, 2025 Link to comment Share on other sites More sharing options...
[Ma...] Posted October 8, 2025 Share Posted October 8, 2025 Basic formulas not involving PCM license are almost all in editor. Then you have a few commands in help file ( manual ) - downloadable at zeiss portal. Undocumented codes are rather somewhere on forum or not easy accessible. Link to comment Share on other sites More sharing options...
[Ke...] Posted October 8, 2025 Share Posted October 8, 2025 (edited) One of the best resources for this will be in the PCM manual that is installed with Calypso, it can be found alongside a number of other manuals in C:\Program Files (x86)\Zeiss\CALYPSO X.x\userinfo\manuals. The manual contains many of the pcm commands, as well as syntax and use case examples for a number of them that can be applied to plenty of common PCM usage scenarios. For newer versions(7.4 and later) the folder will have a bunch of numbered HTML files, these are for F1 help menu built into Calypso, but there will also be the manual PDF files in there as well. Edited October 8, 2025 Link to comment Share on other sites More sharing options...
[La...] Posted October 9, 2025 Author Share Posted October 9, 2025 Please sign in to view this quote. Thank you! I'm still learning Calypso so I had no idea. I appreciate it. Link to comment Share on other sites More sharing options...
[La...] Posted October 9, 2025 Author Share Posted October 9, 2025 Please sign in to view this quote. Thank you! I'll be sure to check out the manual! I greatly appreciate it. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 9, 2025 Share Posted October 9, 2025 You can refer to this as well. Link to comment Share on other sites More sharing options...
[La...] Posted October 9, 2025 Author Share Posted October 9, 2025 Please sign in to view this quote. Thank you kindly! I'll be sure to take a look at this after work. I appreciate you! Link to comment Share on other sites More sharing options...
