[Pa...] Posted October 13, 2025 Share Posted October 13, 2025 I'm currently having trouble finding a good way to measure the 0.035 width called out in the attached image, any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
[Ma...] Posted October 13, 2025 Share Posted October 13, 2025 If you have a curve, then you can try kink point ( i think it's called like that ) - you just scan curve and then use circle and line Link to comment Share on other sites More sharing options...
[Pa...] Posted October 13, 2025 Author Share Posted October 13, 2025 Please sign in to view this quote. Unfortunately I don't currently have curve available. Link to comment Share on other sites More sharing options...
[Ma...] Posted October 13, 2025 Share Posted October 13, 2025 Then you can try whatever is close to real part to measure circle with at least 3 points and restricted radius as drawing states ( or if you can ask on machining what radius they programmed ) this will be the closest you can get Link to comment Share on other sites More sharing options...
