[Ch...] Posted October 14, 2025 Share Posted October 14, 2025 Today when I logged on the CMM it appears as it has reverted to factory settings. We use Calypso 2025 version on a Contura model. I'm new to Calypso and still have a long way to go. I have no idea why this happened or how to fix it. Most of my icons/short cuts for programing are gone. It's popping up the tips menu all the time as if it's a completely new software setup and the icons that remain are about 3 times the size they were. Is there a way to reverse this change? I've looked around and can't find anything, Link to comment Share on other sites More sharing options...
[Ke...] Posted October 14, 2025 Share Posted October 14, 2025 Sounds like your Config may have been lost, try following https://portal.zeiss.com/knowledge-base?id=483015 If that doesnt work, you may be able to try restoring from an Acronis backup (if this is a Zeiss provided pc) https://portal.zeiss.com/knowledge-base?id=1525824 1 Link to comment Share on other sites More sharing options...
