Transform measurement series in kiosk
  • 2 weeks later...
Hi Máté,
you need a second measuring setup with the part flipped, create a new measuring series for this setup and transform the measurement series by common reference points -> 'use common reference points above plane'.
Generally it is recommended to use a fixture, so the sensor can scan the other side in one measurement series, so there is no manual interaction for flipping the part necessary. (If you have access to the Scanbox/Scancobot training, there is a slide for this in the training PDF).
Nanno
Hello Nanno,
Thanks. I am familiar with the general method.
The question is especially interesting for us in the kiosk mode. If you save a template like this, theoretically will the kiosk connect the ref.points by itself? It didn't work for us when we tried it.
Máté
