[Ma...] Posted October 14, 2025 Share Posted October 14, 2025 Hallo zusammen, seit der SW2025 schaltet sich unser Sensor (Triple Scan) nicht mehr automatisch nach 1 oder 2h Inaktivität ab. Wo kann ich das wieder aktivieren? Besten Dank und viele Grüße Martin Krüger Link to comment Share on other sites More sharing options...
[Ma...] Posted October 14, 2025 Share Posted October 14, 2025 There should be web admin panel for that, but i can not see that powersaving as it was presented to us that this option is available. You can access that web by opening your machines ( Help -> System analyze -> ... ) there should be a button to web service. Link to comment Share on other sites More sharing options...
[Ma...] Posted October 17, 2025 Author Share Posted October 17, 2025 Das Web Interface hab ich gefunden, aber da ist nichts um den Sensor bei Inaktivität automatisch ausschalten zu lassen!? Oder ich kann es nicht finden. Link to comment Share on other sites More sharing options...
[Ma...] Posted November 5, 2025 Author Share Posted November 5, 2025 Hat keiner eine Idee? Link to comment Share on other sites More sharing options...
[Na...] Posted November 5, 2025 Share Posted November 5, 2025 Hallo, es gibt anscheinend ein Problem mit der 2025 und dem Triplescan hinsichtlich der automatischen Abschaltung. Ich gebe diesen Thread als weiteren "Fund" weiter. 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted November 5, 2025 Share Posted November 5, 2025 Please sign in to view this username. I found if you in INSPECT turn off ATOS ( laser and projector ) and monitor turns off ( screensaver ), then projector turns on on low brightness. Once mouse movement ( screen turns on ), then projector turns off, like it should be. Only option to keep it turned off i found on web interface Link to comment Share on other sites More sharing options...
