Change the Template folder
  • 2 weeks later...
Hi,
there is no function for this.
As a workaround, you could use the public folder in ZEISS INSPECT.
You can use gom.script.sys.set_public_folder() to change the public folder from a script.
sys.set_public_folder (set public directory) - set public directory
Parameters:
Name      | Description                         | Type                  | Optional
directory | specifies the path to the directory | Tom::Parse::Directory | No
migration | decide whether to migrate or not    | bool                  | Yes
However, this will apply to everything inside the folder, not just templates.
Notes:
  • gom.script.sys.set_public_folder() will take effect in the current ZEISS INSPECT instance immediately.
  • The public folder for other ZEISS INSPECT instances will be changed only after closing the instance which modified it.
Best regards,
Matthias
Edited
