[Li...] Posted October 15 Share Posted October 15 We will be making this very soon. It has a main bore that it is Ø2.250±.002" At the bottom of the bore is a hone relief diameter of Ø2.31±.020 and max depth /width of .20" This is not going to be inspected on a CMM. Manufacturing is looking for a handheld gage that can inspect the ID. We may have something for the depth. Does anyone know of gages for checking hone reliefs? Please see the attached. I know that there are various types of bore gages, but I don't think that's the right type of gage for such a small diameter landing. We're going to need to get all the way down the bore to get the ID. Telescoping gages are a bit too big, the spring-loaded pins are about .225" Lincoln 12IN DEEP HONE RELIEF ID.xlsx Link to comment Share on other sites More sharing options...
[Je...] Posted Thursday at 04:19 PM Share Posted Thursday at 04:19 PM I believe they are called "inreach gages" by Mueller and work well for in-place inspection. Bore gages work for this but are difficult to get to the bottom of a bore of that size/depth ratio. Not promoting them, just making you aware as they are an obscure gage that many are unaware of. Use this while the part is in-place on the machine then take to inspection and measure using a VAST sensor and special stylus setup 2 1 Link to comment Share on other sites More sharing options...
