[Do...] Posted June 3, 2021 Share Posted June 3, 2021 Hello, is it possible to install additional python modules other than what are available now. I would like to use the openpyxl module to create excel files based on existing excel templates and have not been able to figure out how to install the module into the GOM environment. Thank you Link to comment Share on other sites More sharing options...
[Sh...] Posted July 6, 2021 Share Posted July 6, 2021 In versions 2019 and higher, if you open the script editor and look the the System Scripts/Tools folder there will be a locked script called InstallPythonPackage. Run that script and type the name of the module you'd like to install and make sure the "network" radio button is selected if you don't have the module saved locally. Link to comment Share on other sites More sharing options...
[Ma...] Posted December 19, 2023 Share Posted December 19, 2023 Hello, This feature is now integrated in the Add-on Editor - see ZEISS Quality Tech Guide: How to Create an Advanced Add-on. Best regards, Matthias Link to comment Share on other sites More sharing options...
