[Jo...] Posted October 24, 2025 Share Posted October 24, 2025 Hello, I'm looking for the API call for changing the stage range in a table or view on a report page. It is on views I have to do this by open the stage range in the explorer when I edit the view or table on a page. Thanks in advance, Johnny Link to comment Share on other sites More sharing options...
[Ma...] Posted October 24, 2025 Share Posted October 24, 2025 (edited) Hi, you can record those actions. I've recorded "gom.script.sys.show_stage( stage=gom.app.project.stages['stage1'])" You can also record creation of stage range Edited October 24, 2025 Link to comment Share on other sites More sharing options...
[Jo...] Posted October 24, 2025 Author Share Posted October 24, 2025 Hello Martin, It is not about the creation of the stage range, but the selection of the stage range for a report view. This was recorded from start to edit a view including the close of the edit action. gom.script.view.set_tab_visible ( view='left_docking_area', visible=True) gom.script.view.set_tab_visible ( view='properties', visible=True) gom.script.view.set_tab_visible ( view='properties', visible=True) gom.script.view.set_tab_visible ( view='properties', visible=True) gom.script.sys.open_stage_range (element=gom.app.project.stage_markers['C-Final TID']) Not helpful for me. There are gui actions included. Johnny Link to comment Share on other sites More sharing options...
[Ma...] Posted October 28, 2025 Share Posted October 28, 2025 Hi Johnny, maybe in addition to the functions described in Working with stages — App Development Documentation the commands gom.script.sys.enable_stage()/disable_stage() could be used: gom.script.sys.enable_stage (stages=gom.StageSelection (first=gom.app.project.stages['ZEISS Training Object 3'], last=gom.app.project.stages['ZEISS Training Object 3'])) gom.script.sys.disable_stage (stages=gom.StageSelection (first=gom.app.project.stages['ZEISS Training Object 4'], last=gom.app.project.stages['ZEISS Training Object 4'])) So you could enable only the stages needed for a report view, trigger a recomputation if required, export the report and restore the previous set of enabled stages. Hope this helps! Best regards, Matthias Link to comment Share on other sites More sharing options...
