How to change the stage range in a report page by script?
Hello Martin,
It is not about the creation of the stage range, but the selection of the stage range for a report view.
This was recorded from start to edit a view including the close of the edit action.
gom.script.view.set_tab_visible (
	view='left_docking_area',
	visible=True)
	view='properties',
	visible=True)
	view='properties',
	visible=True)
	view='properties',
	visible=True)
gom.script.sys.open_stage_range (element=gom.app.project.stage_markers['C-Final TID'])
Not helpful for me. There are gui actions included.
Johnny
Hi Johnny,
maybe in addition to the functions described in Working with stages — App Development Documentation the commands gom.script.sys.enable_stage()/disable_stage() could be used:
gom.script.sys.enable_stage (stages=gom.StageSelection (first=gom.app.project.stages['ZEISS Training Object 3'], last=gom.app.project.stages['ZEISS Training Object 3']))
gom.script.sys.disable_stage (stages=gom.StageSelection (first=gom.app.project.stages['ZEISS Training Object 4'], last=gom.app.project.stages['ZEISS Training Object 4']))
So you could enable only the stages needed for a report view, trigger a recomputation if required, export the report and restore the previous set of enabled stages.
Hope this helps!
Best regards,
Matthias
