Atos usb table ROT350
Does anyone know if there is a way to access the speed settings on the turn table, either in the software or using code? The start and stop acceleration is too fast for loos parts sitting on the table. Yes i know i could use that black putty that came with the system but it would be nice to access the motor controls. the larger turn tables are much smoother.
Hi,
yes, you can adjust speeds - just go to configuration of hardware ( where you setup table and ATOS ), there is settings to fast and slow rotation and acceleration.
  • Like! 1
