[Ri...] Posted October 27 Share Posted October 27 In my post settings, I have the following code. Please sign in to view this quote. This is supposed to execute the exe file. It happens right after opening the program and running the first part or it just happens when ever. This action is critical, the CMM could easily crash when this happens. I am guessing it may be a load time out issue. How much time does systemCallWithWait allow? This may also affect the writing of "runpart.para". On one run, where I selected a part number, the folder path created was the prior part number, which means the "runpart.para" file was not over written. (That code is not shown). Link to comment Share on other sites More sharing options...
[Ri...] Posted October 27 Author Share Posted October 27 PCM pre settings: //Pre Settings: optest=getRecordHead("u_OperatorName") //Use char Black List here if len(optest)<2 repeat optest=inquireText("Please enter your Stamp ID. Example: M000.") setRecordHead("u_OperatorName",optest) until len(optest)>2 endif idtest=getRecordHead("u_WorkOrderID") //Use char Black List here if len(idtest)<2 repeat idtest=inquireText("Please enter a Work Order ID.") setRecordHead("u_WorkOrderID",idtest) until len(idtest)>2 endif idtest=getRecordHead("u_MachCenter") //Use char Black List here if len(idtest)<2 repeat idtest=inquireText("Please enter a Machining Center.") setRecordHead("u_MachCenter",idtest) until len(idtest)>2 endif coordoveride=="Rough Bore Machine" newy=0 newz=0 Mac_X="" Mac_Y="" measure("Load Alignment") miniselection=getRunID() flag=0 PN="" cd=(getActualInspectionDir()) systemCallWithWait(cd+"\"+"Parameters_2025.exe") cd=(getActualInspectionDir()) readPCMFile(cd+"\"+"runpart.para") if PN==0 cncBreak() endif //Stop CMM if operator canceled //Read Canc-Cont.txt value my_list=readListFile("Canc-Cont.txt") //Extract value from file CanCon=val(getParameterNamed(my_list,2)) if CanCon==1 cncBreak() endif //End. //01.22.24 - Setup Last User information OpName=getRecordHead("u_OperatorName") OpWoID=getRecordHead("u_WorkOrderID") OpPartNumb=getRecordHead("u_PartNumb") OpSerNumb=getRecordHead("u_SerNumb") OpFam=getRecordHead("planid") //Program ID Opminiselection=miniselection //Mini Plan Name OpLastMachCtr=getRecordHead("u_MachCenter") inspPath2 = "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\inspections\Zeiss 1 Block\Eaton Aerospace\PCM Program\" //end //new 10.15.25 inspPath = getActualInspectionDir()+"\" fileName = "setRunID2.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, OpPartNumb, ()) addToFile(inspPath+fileName, getRecordHead("dmesn") ) addToFile(inspPath+fileName, OpWoID, ()) fileName = "setRunID3.txt" inspPath = getActualInspectionDir()+"\" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRecordHead("dmesn") ) //End New if kidney_length_format=="angle" kidney_length_arc = 2*pi*(kidney_bolt_circ_dia/2)*(kidney_angle_arc/360) endif if kidney_length_format=="decimal" kidney_length_arc = kidney_angle_length kidney_angle_arc = 360*kidney_length_arc/(kidney_bolt_circ_dia*pi) endif kidney_operator=2*sin(kidney_angle_arc/2)*(kidney_bolt_circ_dia/2) zoff = ((dia_OD/2)/cos(30))/2 if kidney_bolt_circ_dia>=2 spd=0.2 scanoffset=0.085 kidmeasslot=0.1 endif if (kidney_bolt_circ_dia>=1) and (kidney_bolt_circ_dia<2) spd=0.15 scanoffset=0.075 kidmeasslot=0.06 endif if kidney_bolt_circ_dia<1 spd=0.1 scanoffset=0.065 kidmeasslot=0.05 endif if true_cyl==1 cyl_tol=cyl_tol/2 endif if kidney_width<=0.150 kid_spd=0.0387401 endif if kidney_width<=0.300 kid_spd=0.0787401 endif if (kidney_width>=0.300) and (kidney_width<1) kid_spd=0.1181102 endif if miniselection=="Finished Bore Characteristics" bore_dia=bore_dia_hone bore_dia_tol=bore_dia_tol_hone perp_tol=perp_tol_hone cyl_tol=cyl_tol_hone endif if (num_bores==3) and (miniselection=="Finished Bore Characteristics") setRunID("3 Finished Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==3) and (miniselection=="Rough Bore Characteristics") setRunID("3 Rough Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==3) and (miniselection=="Kidney Characteristics") setRunID("3 Kidney Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==7) and (miniselection=="Finished Bore Characteristics") setRunID("7 Finished Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==7) and (miniselection=="Rough Bore Characteristics") setRunID("7 Rough Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==7) and (miniselection=="Kidney Characteristics") setRunID("7 Kidney Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==9) and (miniselection=="Finished Bore Characteristics") setRunID("9 Finished Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// if (uc_inspect==1) then goto UCchk else goto NoUCchk endif if (uc_inspect==1) and (hob==1) then goto UCchk1 else goto NoUCchk1 endif NoUCchk: if (num_bores==7) and (miniselection=="Rough Bore Characteristics") setRunID("7 Rough Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==9) and (miniselection=="Rough Bore Characteristics") setRunID("9 Rough Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==11) and (miniselection=="Rough Bore Characteristics") setRunID("11 Rough Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==13) and (miniselection=="Rough Bore Characteristics") setRunID("13 Rough Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif goto Measure endif UCchk: if (mmc_req==1) then setRunID("9 Rough Bore Under_Cut_MMC Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New goto Measure else setRunID("9 Rough Bore Under_Cut Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New goto Measure endif UCchk1: if (mmc_req==1) then setRunID("9 Rough Bore Under_Cut_MMC HOB Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New goto Measure else setRunID("9 Rough Bore Under_Cut HOB Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New goto Measure endif Measure: ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// if (num_bores==9) and (miniselection=="Kidney Characteristics") setRunID("9 Kidney Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==11) and (miniselection=="Finished Bore Characteristics") setRunID("11 Finished Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==11) and (miniselection=="Rough Bore Characteristics") setRunID("11 Rough Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==11) and (miniselection=="Kidney Characteristics") setRunID("11 Kidney Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==13) and (miniselection=="Finished Bore Characteristics") setRunID("13 Finished Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==13) and (miniselection=="Rough Bore Characteristics") setRunID("13 Rough Bore Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif if (num_bores==13) and (miniselection=="Kidney Characteristics") setRunID("13 Kidney Characteristics") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) //End New endif //Start new Ring section 01.19.24 if (ring_count==24) and (miniselection=="Rings") setRunID("24 Ring Dimensions") //New 12.12.23 inspPath = getActualInspectionDir()+"\" fileName = "setRunID.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRunID()) endif //End New if (miniselection=="Rings") Machine="Ring Dimensions" endif //end ring section if (miniselection=="Rough Bore Characteristics") Machine="Rough Bore Machine" endif if (miniselection=="Finished Bore Characteristics") Machine="Hone Bore Machine" endif if (miniselection=="Kidney Characteristics") Machine="Kidney Machine" endif if (miniselection=="Steel Bore Characteristics") Machine="Steel Bore Machine" endif if (confirm("The machine for this part is ", Machine,".", " Is this correct?")) coordoveride=Machine else coordoveride=inquireList("Choose correct machine.", "Rough Bore Machine", "Hone Bore Machine", "Kidney Machine", "Steel Bore Machine", "Ring Dimensions") endif //offset_x = + ((kidney_length_arc/2) - (kidney_width/2) - getNominal("LCL1_CIR_LEFT_1").y) //offset_y = getNominal("BASE_RSLT_KIDNEY",1).z + getNominal("LCL1_CIR_LEFT_1").z //redrawCAD() setRecordHead("u_PartNumb",PN) setRecordHead("u_Machine",coordoveride) Link to comment Share on other sites More sharing options...
[Ri...] Posted October 27 Author Share Posted October 27 Additional information. This code was added to the vb.net solution to prevent errors when published. For some reason, when I publish the executable app, it wants to run the app right after install. Module Startup Sub Main() If ApplicationDeployment.IsNetworkDeployed Then If ApplicationDeployment.CurrentDeployment.IsFirstRun Then ' Optionally log or show a message Exit Sub End If End If Application.Run(New Form1()) End Sub End Module The activity in my initial post was not present prior to adding this preventive measure. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 28 Author Share Posted October 28 Mods, please kill this post. Thank you. I need to start a new one that is uncluttered. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 28 Author Share Posted October 28 This needed to be set prior to executing this file: Parameters_2025.exe setRecordHead("u_PartNumb",PN)) Otherwise, my part number was always wrong, it would be the prior part instead of the current part. Link to comment Share on other sites More sharing options...
