[Ri...] Posted October 29, 2025 Share Posted October 29, 2025 I want to make this code recognize "YES", "Yes" or "yes". //04.01.25 RS Run=inquireText("Is the Block Fixture moved out of the way?"+cr()+"You can move the fixture now."+cr()+"User must answer YES to continue."+cr()+"CMM will stop if not YES.") if Run == "YES" else cncBreak() endif //End edit I am not structuring something properly and I can't wait to see how simple it is so I can laugh at myself. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 29, 2025 Share Posted October 29, 2025 Well if the answers are only Yes/No, I would just use confirm instead of inquireText. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted October 29, 2025 Share Posted October 29, 2025 But you can use case conversion if you are trying to convert. Run = inquireText("Is the Block Fixture moved out of the way?" + cr() + "You can move the fixture now." + cr() + "User must answer YES to continue." + cr() + "CMM will stop if not YES.") if text(Run).asUppercase == "YES" // continue else cncBreak() endif 2 Link to comment Share on other sites More sharing options...
[Ch...] Posted October 29, 2025 Share Posted October 29, 2025 (edited) There are also the following : .asLowercase and .asCapitalized and also : .startingWithUppercaseLetter Edited October 29, 2025 1 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted October 29, 2025 Author Share Posted October 29, 2025 Please sign in to view this quote. Well, that simplified the process. Thank you. Link to comment Share on other sites More sharing options...
[Pi...] Posted November 19, 2025 Share Posted November 19, 2025 If I may ask - what is the difference in code between: .asUppercase ---> all letters are Upper case .asCapitalized ---> ????? this one I do not understand - Please explain if possible as for me it is same as the one below. .startingWithUppercaseLetter ---> First letter is Upper case 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted November 19, 2025 Share Posted November 19, 2025 Capitalized should make first letter from word in upper case. Example: Hello there fellow comrades -> Hello There Fellow Comrades 1 Link to comment Share on other sites More sharing options...
