Using "else" in an "if" statement.
I want to make this code recognize "YES", "Yes" or "yes".
//04.01.25 RS
Run=inquireText("Is the Block Fixture moved out of the way?"+cr()+"You can move the fixture now."+cr()+"User must answer YES to continue."+cr()+"CMM will stop if not YES.")
if Run == "YES"
else
cncBreak()
endif
//End edit
I am not structuring something properly and I can't wait to see how simple it is so I can laugh at myself.
But you can use case conversion if you are trying to convert.
Run = inquireText("Is the Block Fixture moved out of the way?" + cr() + "You can move the fixture now." + cr() + "User must answer YES to continue." + cr() + "CMM will stop if not YES.")
if text(Run).asUppercase == "YES"
  // continue
else
  cncBreak()
endif
  • Like! 2
  • 3 weeks later...
If I may ask - what is the difference in code between:
.asUppercase  ---> all letters are Upper case
.asCapitalized ---> ????? this one I do not understand - Please explain if possible as for me it is same as the one below.
.startingWithUppercaseLetter ---> First letter is Upper case
