[Du...] Posted October 30, 2025 Share Posted October 30, 2025 Unsure if this is where this should be, BUT here we go I have a MAXDEV callout of an element group that I'm looking to multiply by 2 and report out that number (MAXDEV) as a pass fail in the report of the project. Been playing with Check User Defined and there isn't a lot of information on this feature that i could find. Is there a feature that i can create this callout mathematically and place that keyword within the report for the pass fail? Link to comment Share on other sites More sharing options...
[Ma...] Posted October 30, 2025 Share Posted October 30, 2025 You would need to create User check on that element and fill into actual that formula ( actual. -> should appear menu with options ) Link to comment Share on other sites More sharing options...
[Du...] Posted October 30, 2025 Author Share Posted October 30, 2025 Please sign in to view this quote. Thank you, when i type in or select actual.-> i dont get any options for math. Append, sort, and unique is my only options. When i *2 the actual, i get, value should be "DOUBLED" error Link to comment Share on other sites More sharing options...
[Du...] Posted October 30, 2025 Author Share Posted October 30, 2025 ok i got the formula but now its converting it to MM, while the whole project is in IN Link to comment Share on other sites More sharing options...
[Du...] Posted October 30, 2025 Author Share Posted October 30, 2025 Ok figured out the formula now to figure out the decimal places Link to comment Share on other sites More sharing options...
[Du...] Posted October 30, 2025 Author Share Posted October 30, 2025 Edit - Preferences - Default Units - Values without Units Decimal Link to comment Share on other sites More sharing options...
[Ri...] Posted October 31, 2025 Share Posted October 31, 2025 You probably don't want to leave it as a Value without Units. Just set the Unit to Length inside of the Check User-Defined. Link to comment Share on other sites More sharing options...
