[Ch...] Posted October 31, 2025 Share Posted October 31, 2025 Dear Community, I would appreciate it if someone could provide a definitive answer regarding the minimum system requirements for ZEISS Correlate. I am planning to use the software to measure 2D deformations and therefore do not see the need to invest in an expensive system. Could you please let me know if the following system would be sufficient? I am particularly uncertain about whether the integrated graphics card will be adequate. Thank you very much for your help and insights. Configuration: Intel core ultra 5 228 V, 32 GB RAM, Windows 11 Pro, 1TB SSD, Intel Arc Graphics 130 v best regards Link to comment Share on other sites More sharing options...
[Mo...] Posted December 18, 2025 Share Posted December 18, 2025 Dear Chiranjeet, While I understand your intention to avoid investing in an expensive system, I must recommend using one of Zeiss certified PCs specifically designed for optimal performance with our software. These configurations have been thoroughly tested and validated to ensure compatibility and efficiency with ZEISS Correlate. Unfortunately, I cannot provide a definitive answer regarding your specific configuration (Intel Core Ultra 5 228 V, 32 GB RAM, Windows 11 Pro, 1TB SSD, Intel Arc Graphics 130 v) as we have not tested this setup with our software. The integrated graphics card may not meet the performance standards required for accurate 2D deformation measurements. Regards, Mohamed Link to comment Share on other sites More sharing options...
