Spatial rotation to multiple planes C2018
How to align spatial rotation to multiple parallel planes?
This is how I do it, but it isn't the quickest way, is it?
1. measure space points at the planes, sometimes using a pattern
2. create offset points by "Recall one feature" point by point manually and adding offset value
3. create a "DatumPlane" by "Recall" of all the offset points (I get a suggestion to use "Recall feature points" instead but I can't use theoretical offset points this way)
4. Align Spatial Rotation to the DatumPlane
Wouldn't this way carry evaluation error due using previously defined axis?
Wouldn't be better to use symmetries of planes if you need to compensate many planes ( more than 3 points )?
If you need it as a datum, then using surface feature would be better ( to carry more of measured points ). Then use bestfit on that feature
First off - I would never recommend to define the Nominal Geometry with Actual Geometry, and then especially use that in the Base Alignment. Nominals should not be constantly changing.
I've used this method for many years across 3 Zeiss software packages and it works, but I don't know if it conforms to any standard.
But you definitely need to iterate (loop) your base alignment a few times when using this.
I collect ~30 points. Best fit is an idea. Way quicker! Thank you. The drawback is that I can't get a flatness if the join plane but there's other solution
Why? I need Z actuals and I don't tolerate the results
As long as it works and gives reasonable results, it's good : )
I'm just saying that it's probably not the best idea to have your nominals constantly changing. There's no reason why you should use the actual as the nominal.
Thank you for you input
When I use getNominal instead of getActual, the actual value of offset Point equals nominal value of original Point
