[Ri...] Posted November 4, 2025 Share Posted November 4, 2025 Well, I found out why I am not changing the partbinc value, I have several mini plans and in the inspect file it is being written for each mini plan used as a separate partbinc line. So, now I am using the file "protheadpara" to obtain the value I want to check for invalid characters and set the partbinc value because this value changes regardless of the mini plan (I think Richard Shomaker led me down this path. 😉 ) Except I am stuck on indexing the list from the protheadpara file. PCM doesn't like this line: "currentLine = fileLines[i]". It reports an error that fileLines[i] is not defined. Any assistance is appreciated. // Define list of invalid characters/sequences NOT_ALLOWED_LIST = list("~", "`", "!", "@", "$", "%", "^", "&", "*", "(", ")", "+", "=", "{", "}", "[", "]", "|", ":", ";", "'", "<", ">", ",", ".", "/", "\\", "?", "--", "__") NOT_ALLOWED_LIST_NAME = "NOT_ALLOWED_LIST" // Build full file path (no suffix) inspPath = getActualInspectionDir() + "\\" fileName = inspPath + "protheadpara" // Read file into a list fileLines = readListFile(fileName) // Initialize variable sernotest = "" // Loop through lines to find partnbinc for i = 1 to fileLines.size currentLine = fileLines[i] // Correct way to access list element? if inStr(currentLine, "partnbinc,") <> 0 then // Extract value after comma sernotest = strElement(2, ",", currentLine) i = fileLines.size + 1 // Exit loop endif next i // Backup original value sernotest2 = sernotest // Validation loop repeat invalid_found = false // Check against NOT_ALLOWED_LIST for not_allowed_index = 1 to NOT_ALLOWED_LIST.size this_not_allowed_str = getParameterNamed(NOT_ALLOWED_LIST_NAME, not_allowed_index) attempt = inStr(sernotest, this_not_allowed_str) if attempt <> 0 then message("Invalid character '" + this_not_allowed_str + "' found in input '" + sernotest + "'. Please re-enter a valid value.") sernotest = inquireText("Please enter the correct \"Serial Number or numeric counter value\".") invalid_found = true not_allowed_index = NOT_ALLOWED_LIST.size + 1 // Force exit from for-loop endif next not_allowed_index // Additional explicit check for consecutive dashes or underscores if inStr(sernotest, "--") <> 0 or inStr(sernotest, "__") <> 0 then message("Invalid sequence '--' or '__' found in input '" + sernotest + "'. Please re-enter a valid value.") sernotest = inquireText("Please enter the correct \"Serial Number or numeric counter value\".") invalid_found = true endif until invalid_found == false // Final assignment setRecordHead("u_partnbinc", sernotest) Link to comment Share on other sites More sharing options...
[Ri...] Posted November 4, 2025 Author Share Posted November 4, 2025 Edit: " I have several mini plans and in the inspect file it is being written for each mini plan used as a separate partbinc line." should be " I have several mini plans and in the inspset file it is being written for each mini plan used as a separate partbinc line." Link to comment Share on other sites More sharing options...
[Er...] Posted November 11, 2025 Share Posted November 11, 2025 (edited) Well your error message says it all. It's not defined. You have a List-object in "fileLines", and to access each index in that list you can use getParameterNamed(var,index) To define fileLines[i] you need to, as an example do someting like this: for i = 1 to fileLines.size fileList[i] = getParameterNamed(fileList,i) next i And that seems counter intuitive in this case... Anyway, you can simplify all of this a lot. Here is a example: //Read partnbinc for i = 1 to fileLines.size if inStr(getParameterNamed(fileLines,i), "partnbinc,") <> 0 dirtyRecordHead = strElement(2, ",", getParameterNamed(fileLines,i)) i = fileLines.size + 1 // Exit loop endif next i //Remove illegal characters cleanRecordHead = "" for i = 1 to len(dirtyRecordHead) selectCase getParameterNamed(dirtyRecordHead.asArray,i).asUppercase.asInteger case 48 to 57, 65 to 90 //Include 0-9, a-z and A-Z cleanRecordHead = cleanRecordHead + chr(getParameterNamed(dirtyRecordHead.asArray,i)) endSelect next i setRecordHead("partnbinc",cleanRecordHead) Edited November 11, 2025 Can't spell, slightly retarded... 3 Link to comment Share on other sites More sharing options...
