[gr...] Posted Monday at 07:11 PM Share Posted Monday at 07:11 PM Hello everyone. Is it possible to add measurement plan info (it's location) to the pi web header? Like C\users\xxxx\xxxxx I tried searching around forum but couldn't find an answer. Thanks in advance Link to comment Share on other sites More sharing options...
[Ma...] Posted Monday at 07:35 PM Share Posted Monday at 07:35 PM Asking for Calypso? Here is my thread for that - hope you find your way. Link to comment Share on other sites More sharing options...
[gr...] Posted Monday at 08:35 PM Author Share Posted Monday at 08:35 PM thanks I will try that Link to comment Share on other sites More sharing options...
[gr...] Posted Tuesday at 04:17 PM Author Share Posted Tuesday at 04:17 PM Would there be a way to add an extra field in pi Web for that ? Link to comment Share on other sites More sharing options...
[Ma...] Posted Tuesday at 05:16 PM Share Posted Tuesday at 05:16 PM I am not sure what you are looking for. PiWeb will show only what was sended from Calypso. So if you want to pass some info, you have to use user defined field ( same for start headers ) You can link that info into Kfield or use another way to show that info in PiWeb report. To fill that field you have to use PCM code or hardcoded text. Used either on feature or characteristic. On which step are you stuck or from where you want to fill that info? Link to comment Share on other sites More sharing options...
[gr...] Posted yesterday at 04:06 PM Author Share Posted yesterday at 04:06 PM I was hoping to use "select report header parameters"option and add additional field to pi web report. Would You know what hardcoded text i would need for that. Sorry I haven't dealt with pi web much. Never needed to make changes to report Link to comment Share on other sites More sharing options...
[Ma...] Posted yesterday at 04:27 PM Share Posted yesterday at 04:27 PM (edited) When you havee this window, then move mouse pointer onto correct row ( what you want to add ) and column with "?" - it will popup a hint, what you need to write into PiWeb template. Or in that link what i reposted or somewhere in forum you can find a way with usage of context menu. Edited yesterday at 04:28 PM Link to comment Share on other sites More sharing options...
