[Ch...] Posted November 10, 2025 Share Posted November 10, 2025 Good afternoon everyone, I am having troubles when evaluating 2D curve via Measured point display. We recently switched from Calypso 2020 to 2024 and prior to that we used the measured point display when instructing operators on depth adjustment using distance between points. I can still kind of use this method, but it is much harder to visualize using the radii of the two lines. As you can see in my attachment, even with "lines" selected, it displays dots and pushes the line far above the CAD model and its true location. When I lower that "20" magnification to "1" it just reduces the dot magnification. Red arrows indicate where I want the line to go. 😒 What happened to these lines? Link to comment Share on other sites More sharing options...
