[Ca...] Posted 20 hours ago Share Posted 20 hours ago (edited) I'm trying to find the intersection of two radius doing offline programming but Calypso said no result Edited 20 hours ago Link to comment Share on other sites More sharing options...
[Je...] Posted 20 hours ago Share Posted 20 hours ago Hi. I've seen this type of situation occur. Usually, it means that the actual result calculated that there was in fact no intersection between the two calculated circles. Instead, I usually evaluate via curves or by intersecting a line from the center of one of the two circles to the other at the nominal intersection. There are a few ways to handle it. Link to comment Share on other sites More sharing options...
[Ca...] Posted 20 hours ago Author Share Posted 20 hours ago Jeff, the problem is Calypso cannot make a nominal intersection and I don't have curve. How would you tackle it? Link to comment Share on other sites More sharing options...
[Ky...] Posted 20 hours ago Share Posted 20 hours ago You can't intersect the circles because technically they don't intersect, at least nominally. They are tangent to each other, which the Calypso intersection constructions doesn't count. Best option, especially without curve, would be to measure the circles at the same height, use recall in a 3D line to make a line connecting their centers and then intersect that line with either circle. You WILL get slightly different values depending on which circle you select, but the difference does give you an idea of how good the part is there. 3 Link to comment Share on other sites More sharing options...
[Ja...] Posted 18 hours ago Share Posted 18 hours ago (edited) Could you also measure those radii as partial cylinders instead of circles? You should be able to get an intersection between those. You may also need to add some constraints depending on the size of those radii for accuracy and repeatability. Edited 18 hours ago Link to comment Share on other sites More sharing options...
[Je...] Posted 16 hours ago Share Posted 16 hours ago Kyle explained it well. I'd recommend following his suggested strategy. Link to comment Share on other sites More sharing options...
[Je...] Posted 11 hours ago Share Posted 11 hours ago Have a look here, where the same problem is solved: 1 Link to comment Share on other sites More sharing options...
