Saved file corrupt
Don't you hate it when you saved a program after a whole day work and then to have it corrupt when you opened it. I opened other programs just fine and this program isn't even big.
Happens in v2022 as well, recently last week where I had to re-program a job.
Over the decades I have learned how to rob from inspect and inspection files to rebuild.
You can usually get back 90% or so of the program by moving the "inspection" file in the program folder to a new program (assuming that the inspection file isn't corrupted). It won't have the CAD or anything, but you can replace at least most things pretty easily. I would, of course, be careful running it the first time, but it might help you.
  • Like! 2
At least with a PCM-heavy programs you should check the inspset too, as all code from parameter windows is in there.
That's a good point, Norbert. I did forget about that. Inspset is a good one to try to move over, too (again, assuming that the issue isn't in that file).
I did not realize my post was autocorrected to Inspect instead of inspset.
