[Ja...] Posted November 26, 2025 Share Posted November 26, 2025 Using the new GD&T engine, I haven't been able to enter more than one feature into a characteristic to check the bolt holes to themselves. I saw in another thread somebody was recalling other characteristics into a new characteristic to analyze bolt patterns. I'm not able to do that as well. And I tried manually creating a bolt circle but that didn't work either. It was easy using the old characteristics. I get the feeling I'm missing something really simple. What is it? Link to comment Share on other sites More sharing options...
[Ky...] Posted November 26, 2025 Share Posted November 26, 2025 (edited) Hello Jack, The process works a bit differently in the new GD&T engine. This knowledge base article goes through the process, but in short, you need to make a separate callout for each (using the paintbrush tool is the easiest way) and then set all of the callouts to be in sim req or CZ (depending on the standard). https://portal.zeiss.com/knowledge-base?id=3450000 That being said... it does say "Sep Reqt" in the print? Are they not meant to be separate, or is that referring to something else? Edited November 26, 2025 1 Link to comment Share on other sites More sharing options...
[Ja...] Posted November 26, 2025 Author Share Posted November 26, 2025 (edited) Thanks Kyle. I'll check it out. As far as the separate requirement goes, there are other bolt patterns on the part that use the same callout and so I'm thinking each pattern needs to be in the right place and good to itself, but one pattern to another pattern isn't critical. Edited November 26, 2025 Add clarification. Link to comment Share on other sites More sharing options...
[Ja...] Posted November 26, 2025 Author Share Posted November 26, 2025 Kyle - The link worked, but I don't see that article listed when I go to the Knowledge Base. Is there another list of articles that we can access? Link to comment Share on other sites More sharing options...
[Ma...] Posted November 27, 2025 Share Posted November 27, 2025 Please sign in to view this quote. Go here ZEISS ID And change your Country to United states of America. This way you wil see content and not binoculars 🙂 Link to comment Share on other sites More sharing options...
[Ja...] Posted December 1, 2025 Author Share Posted December 1, 2025 The link brought me to my own account page. The Knowledge Base articles didn't change. Link to comment Share on other sites More sharing options...
[Ky...] Posted December 1, 2025 Share Posted December 1, 2025 That's strange. Are you not in the US, Jack? I though you might have been. If you want to message me directly and give me your email, I can send you a PDF version. Link to comment Share on other sites More sharing options...
