[He...] Posted December 2, 2025 Share Posted December 2, 2025 I have a very large cylindrical part. Print requires position of cylinders along axis with the primary datum in DRF as 2 cones on opposite ends of the part labeled B-C. My secondary datum is a plane perpendicular to the axis. I currently have a 3d line recalling the cones and using that as the primary datum. Is that correct? Print is to ASME. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 2, 2025 Share Posted December 2, 2025 They want it held between those two centers. You're going to have to have a discussion with your customer on a compromise on measuring this part. Link to comment Share on other sites More sharing options...
[Ky...] Posted December 2, 2025 Share Posted December 2, 2025 I don't see datum B on the print sample you showed but if they are on opposite sides of the part, you are on the right path. I wouldn't even bother measuring C as a full cylinder. It's too short to really be measured as such. I would probably measure it as a circle on cylinder (should just be able to click with the circle making tool if you have a CAD) and then make a 3D line using recall between the two circles (note, it must be recall and not recall feature points). That's how I would make B-C Link to comment Share on other sites More sharing options...
[Ri...] Posted December 3, 2025 Share Posted December 3, 2025 Use circle on a cone for both centers. Link to comment Share on other sites More sharing options...
[Ma...] Posted December 3, 2025 Share Posted December 3, 2025 I would use Circle on a Cone on both ends and create a 3D Line between those circles. Link to comment Share on other sites More sharing options...
[DW...] Posted December 3, 2025 Share Posted December 3, 2025 Please sign in to view this quote. Please sign in to view this username. Please sign in to view this username. Richard is on the money here. Of all the things I have measured with the CMM, the runout/position of cylinder axes on shafts is the most difficult, especially if the manufacturer is grinding/lapping. It's all in the setup, which requires some very specific equipment. To get the most accurate and best correlating results with the shop floor, you are going to need a surface plate, bench center with appropriate sized anvils, and a high resolution dial or digital indicator. The CMM just falls short in these types of measurements (in my opinion). Best of luck sir. Link to comment Share on other sites More sharing options...
