[Ma...] Posted 2 hours ago Share Posted 2 hours ago I have a similar question, I have a plane called back to two datums, one is another plane -D- which makes sense as it would just be a tolerance zone of parallel planes but its also dimensioned to C which is a circle which can only control translation which seems weird as parallel plane can rotate and move and it wouldn't change anything in my mind, I only have experience with Positional call-outs from a plane to a plane but this one is also at an angle and D is not at an angle, how would I go about setting this up? Link to comment Share on other sites More sharing options...
[Ma...] Posted 2 hours ago Share Posted 2 hours ago We are using surface profile for this callout Link to comment Share on other sites More sharing options...
[Ma...] Posted 41 minutes ago Author Share Posted 41 minutes ago I didn't make the drawing; I need to inspect it as it's called out. Link to comment Share on other sites More sharing options...
[Ma...] Posted 25 minutes ago Share Posted 25 minutes ago Then use TP for that Link to comment Share on other sites More sharing options...
