automatic saving of the measurament result
First you have to have defined name of pdf file for correct protocol ( PiWeb, older presentation ) and checked PDF button to save them.
Naming is searchable on forum and PDF button is in multiple protocols window. Not at Calypso right now to send screenshots.
  • 6 months later...
or
Then
Choose what you need. Just remember to use variables otherwise you will be overwriting the same file over and over.
