[Fe...] Posted December 5, 2025 Share Posted December 5, 2025 Buongiorno, potresti aiutarmi a capire come salvare automaticamente i report delle misurazioni in Calypso? Grazie. Link to comment Share on other sites More sharing options...
[Ma...] Posted December 5, 2025 Share Posted December 5, 2025 First you have to have defined name of pdf file for correct protocol ( PiWeb, older presentation ) and checked PDF button to save them. Naming is searchable on forum and PDF button is in multiple protocols window. Not at Calypso right now to send screenshots. Link to comment Share on other sites More sharing options...
[Fe...] Posted December 5, 2025 Author Share Posted December 5, 2025 I KNOW THE PDF BUTTON TO SAVE THE FILE, BUT THERE IS ALSO ANOTHER WAY TO SET THE AUTOMATIC SAVE IN THE CALYPSO MEMORY Link to comment Share on other sites More sharing options...
[Pi...] Posted June 16 Share Posted June 16 or Then Choose what you need. Just remember to use variables otherwise you will be overwriting the same file over and over. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 16 Share Posted June 16 Attached is a text file I use for data retention. Use as you wish. Sample PCM for file saving.txt 2 1 Link to comment Share on other sites More sharing options...
[Fe...] Posted 5 hours ago Author Share Posted 5 hours ago Please sign in to view this username. Please sign in to view this quote. Link to comment Share on other sites More sharing options...
[Ri...] Posted 4 hours ago Share Posted 4 hours ago (edited) The PCM scripts create files in locations you decide (The drive and path). It creates folders if they do not exist. It places files in the folders created or existing. It will never overwrite a file due to the Date and Time stamp appended to the file name. It is also based on user information in the "Definition of Multiple Report" section. I use: Drawing No. Incremental Part Number (Used as a counter and or serial numbers) Order Start Comment (in case you want to add a comment) Workpiece Rev. (Used for drawing revision) All of these are part of the variables in the script I attached in my prior post. Edited 4 hours ago 1 Link to comment Share on other sites More sharing options...
