[Jo...] Posted 13 hours ago Share Posted 13 hours ago Just installed calypso 2025 on my offline seat. Set everything up... machine tabs, rotary table, etc... Lots of problems... 1) when opening program, work piece looks to be 6-7" into the machine. 2) Cannot probe the machine "plate surface" 3) trying to establish RT... if I open the base alignment and do a manual alignment, it flips the part about 105 degrees towards the back of the machine... if i just open then close and let the machine do it, it will flip the part 180 degrees (upside down). I have been doing the planner since 4.0 and never had this before. I contacted Zeiss but thought maybe someone has had this happen... Note all my machines are on 2020 with a RT01 and not an AB... I don't know if this is what causing the issues (can't see why because its virtual on planner) Link to comment Share on other sites More sharing options...
