Where is report header data saved?
Hello,
I have a new cmm computer to set up.  Whenever I fillout the report header data from Resources->Report Header Parameters (i.e. work order, part number, rev, ect.), it does not save it.  If I fill it out and immediately go back to in, it is back at the default values.
I have an assumption that it is a permissions issue since it acts as if calypso just doesnt have the write permissions to whatever location that info is stored.  So is there a specific file location I can check to see if we have read/write?  Or could there be another issue?
Thanks
https://qualityforum.zeiss.com/topic/25319-where-is-report-header-data-saved/
This was the solution.  The userfields.ini had a defaultValue=XXXXX.  And removing the XXXXX part of it made it work.  The confusing part that made it hard to figure out was that every other calypso 2024 installation on the other machines did not act like this (they have default values) but this one new computer needed them blank.
I was facing similar thing on new pc with Calypso 24 - in autorun we had stored pallet programs with headers prefilled - but on new Calypso this was overriden by this "default" value.
Also i miss changing comboboxes - on older versions you could focus header and by clicking on keyboard arrows you could change it's value - now it's opening that list.
It's a little annoying, but we can live with that 😄
