[Da...] Posted yesterday at 03:39 PM Share Posted yesterday at 03:39 PM Hello, hopefully this is a simple question. I want the distance between the inner edges of the slots. When I use caliper distance, it only gives me the option of center to center. I think I can do a result element with a formula to take the center to center distance and subtract half of each slot length, but is there a simpler way? Link to comment Share on other sites More sharing options...
[Ky...] Posted yesterday at 04:06 PM Share Posted yesterday at 04:06 PM Honestly the easiest method would probably be make the relevant circles and then recall the data in that relevant area into them and use caliper distance on those. The other "simpler" way would be to use this caliper distance than use a result element to subtract out half of the length from both cylinders, like how we used to do it before the caliper distance characteristic. There are a couple other methods I can think of, but they would be a bit more involved than either of those solutions and would give pretty close to the same result regardless. Link to comment Share on other sites More sharing options...
[Da...] Posted 6 hours ago Share Posted 6 hours ago You could also create a theoretical line and intersection point between the rad and the line and check the distance. Link to comment Share on other sites More sharing options...
[Pa...] Posted 5 hours ago Share Posted 5 hours ago Yes, I'd go back in and probe those circles in addition to the slot. Caliper distance between those two circles will give you what you need. I suspect caliper distance between those two slots is not "seeing" circles at the ends. Link to comment Share on other sites More sharing options...
