[Ma...] Posted December 10, 2025 Share Posted December 10, 2025 I've heard this rule several times but I can't find the definition of it anywhere and I was wondering if anyone has a PDF or something I can reference to use it. Link to comment Share on other sites More sharing options...
[Ky...] Posted December 10, 2025 Share Posted December 10, 2025 I'm afraid I can't find one, at least not one that I feel comfortable sending out since we don't make it. If you want a simple step by step breakdown, you go through this process for all 6 degrees of freedom possible in a rigid object (i.e. translation and rotation in X, Y and Z): Â 1. Can - Is the datum physically capable of constraining this degree of freedom? For instance, a plane with the axis in the Z direction can stop translation in the Z, but it CANNOT stop translation in either the X or Y (think of putting that plane on the granite of the CMM, you can't push it further in the Z, but you can slide it in the X and Y as much as you like). Likewise, a cylinder or circle in Z axis can stop translation in the X and Y, but not in the Z (think of putting a pin in the feature). Â 2. May - Is there a higher priority datum already constraining that degree of freedom? If two datums pass step 1, then the one that comes earliest in the datum structure of the callout gets priority (that's why its primary, secondary and then tertiary). Â 3. Must - If the datum fulfills the requirements in step 1 and 2, then this datum MUST control that degree of freedom. Â Hopefully this helps, at least a little. I know it isn't the PDF you were looking for, but in terms of concise explanations, hopefully that gets the job done. 3 Link to comment Share on other sites More sharing options...
[Ma...] Posted December 10, 2025 Share Posted December 10, 2025 I think on Calypso it's working like what is first it's taking whatever is possible. Exceptions are for points and circles - they should not give vectors - only position. I like it in Zeiss Inspect, where you see result. Also Inspect is much advanced about coordinate systems. It allows you to select multiple features to act like pattern and you can also select if you want from it only direction or point also. So here is an example: Primary: circle -> origin Secondary: line -> rotational axis Tertiary: plane -> stopping rotation 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted December 10, 2025 Share Posted December 10, 2025 can may must rule: if a datum feature can (is physically able to) and may (is permitted to by the drawing) constrain a degree of freedom (DOF), then it must do so. Most often, your primary datum will constrain 3 degrees of freedom, your secondary will constrain 2, and your tertiary will constrain 1.  But not always, it all depends on what your datum 'can may and must' constrain.  2 Link to comment Share on other sites More sharing options...
[Pa...] Posted December 11, 2025 Share Posted December 11, 2025 You won't find it in a standard. It's a "rule of thumb" meant to simplify what IS in the standards. Link to comment Share on other sites More sharing options...
[Sh...] Posted December 11, 2025 Share Posted December 11, 2025 Please sign in to view this quote. Just reference Please sign in to view this username. / Please sign in to view this username.  to anyone or any emails you have to address. He'll set em straight! 🙃 Link to comment Share on other sites More sharing options...
[Ra...] Posted December 11, 2025 Share Posted December 11, 2025 Please sign in to view this quote. I can vouch for Mark Foster. Best ASME class I ever took with him as the instructor. Link to comment Share on other sites More sharing options...
Popular Post [To...] Posted December 11, 2025 Popular Post Share Posted December 11, 2025 anyone notice that Can, May, Must = CMM 5 1 Link to comment Share on other sites More sharing options...
