[An...] Posted December 11, 2025 Share Posted December 11, 2025 Hi, We calibrate our probes weekly but I started to wonder if we should take a look at the probes under a microscope as well. Is the anyone who does this and has that routine? Have you seen any benefits from it? Do you find wear that you normally don't catch during calibration? Link to comment Share on other sites More sharing options...
[Ri...] Posted December 11, 2025 Share Posted December 11, 2025 I carry a 7x eye loop, I look at styli every day. Link to comment Share on other sites More sharing options...
[An...] Posted December 11, 2025 Author Share Posted December 11, 2025 Please sign in to view this quote. What do you think are the advantages of doing this? Do you find a lot of wear that would otherwise not be detected? I'm trying to find reasons for my boss to buy a microscope 😁 Link to comment Share on other sites More sharing options...
[Ri...] Posted December 11, 2025 Share Posted December 11, 2025 Whenever I have results that are not as expected, I inspect the stylus that measured the feature with my eye loupe. This aids in detecting and correcting buildup and or debris on the stylus. If the stylus is dirty or has buildup, clean it. If the stylus is clean and free of buildup, inspect the feature for debris, etc, clean and remeasure. 9.96 out of ten times this clears an OOT condition quite quickly. Link to comment Share on other sites More sharing options...
[Jo...] Posted December 11, 2025 Share Posted December 11, 2025 The main advantage is piece of mind and a good basis for reliable results. I inspect our probes visually before every calibration (after cleaning) and like Richard everytime i got unexpected results. Depending on the location of the defect or buildup and your calibration sequence you won`t detect all problems with a probe just through calibration. The microscope is also important for the visual inspection of measurement objects before measurement in my opinion. How can you otherwise put unexpected results into context? Link to comment Share on other sites More sharing options...
[An...] Posted December 12, 2025 Author Share Posted December 12, 2025 Please sign in to view this quote. Thank you.. That's exactly how my thoughts go too. It's fun to hear how you others do it and what your routines are. Link to comment Share on other sites More sharing options...
[Ch...] Posted December 18, 2025 Share Posted December 18, 2025 In the past, we checked the pushbuttons every day. Now it's only once a week. Management and production thought that was too much. In my opinion, as an old gray-haired metrologist, that's not enough. It also always depends on the range of parts, how good the colleagues are at reporting a collision... That is a never-ending story 👻 with the calibration. Link to comment Share on other sites More sharing options...
[Jo...] Posted January 6 Share Posted January 6 I have been checking weekly for two years and have never found a defect in the probe TIP with the microscope. We have however detected cracking/failure of probe SHAFTS and that has been somewhat useful. I found that carrying the probes from the CMM to the microscope was an unacceptable risk and have my own little microscope by the CMM. (<$150) Link to comment Share on other sites More sharing options...
