[Cl...] Posted December 12, 2025 Share Posted December 12, 2025 (edited) I have a family of parts. The geometry is the same, but each P/N changes size in all axis. My base alignment uses (in-part) two angled planes to construct a symmetry plane for X Each of the parts, the two planes have a different angles and XZ coordinates. I have those variables in a para file for the first part. The problem is, I don't know the best way to move the points with PCM as the planes change. Do I have to have XYZ for each of the 4 points for each plane? Or is there a simpler way? Edited December 12, 2025 Link to comment Share on other sites More sharing options...
[Bl...] Posted December 12, 2025 Share Posted December 12, 2025 Is it at all possible to use a search distance for each individual point? Or maybe take one point that you know will touch in a location every single time with search distance. Then your individual plane points can reference back based off where that search distance point was taken? I think I understand what you're asking, but if I don't then disregard that message Link to comment Share on other sites More sharing options...
[Cl...] Posted December 12, 2025 Author Share Posted December 12, 2025 I understand. I have to use PCM. There are 5 groups 9 sizes and 45-part numbers. All in 5 separate programs. Link to comment Share on other sites More sharing options...
[Bl...] Posted December 15, 2025 Share Posted December 15, 2025 Sorry for the late reply, how did you decide to move forward? Link to comment Share on other sites More sharing options...
[Cl...] Posted December 16, 2025 Author Share Posted December 16, 2025 No problem BlueSky. I figured out part of the problem. I'm still struggling with another part of it. Link to comment Share on other sites More sharing options...
