DMO imort
How can I set the import of the next row.
(Messsuerements Attributes)
ON = 123456
I want to load "123456" into the Order Number(K53) field.image.thumb.png.1474980c4bed4e116157cb346cea9ad8.png
Hi,
that doesn't necessarily mean anything. What happens when you try to import the file? Is the attribute set? If not, I would ask you to contact your local support and open a ticket. To analyse the behaviour, we will need the version, the database configuration, the import configuration and the DMO file.
