[Sv...] Posted December 15, 2025 Share Posted December 15, 2025 hello! I would like to get the transformation from the initial pose of the 'actual' geometry to the pose after alignment. I could not find any accessible way. Specifically I am looking for the offset + rotation XYZ + Rx,Ry,Rz, but would be also happy with any other form of the pose transform. I'm using Zeiss inspect 2025 (free license) Link to comment Share on other sites More sharing options...
[Na...] Posted December 16, 2025 Share Posted December 16, 2025 Hi Sven, the basic workflow would be: (switch to initial alignment) create nominal local coordinate system on CAD or nominal geometry-> measuring principle 'referenced construction' if you don't want to refer to geometry elements, you can create a local coordinate system 'by orientation' and use 'copy as actual' select the actual local coordinate system -> properties and check 'alignment required' check nominal coordinate system with I-Inspect for position and angles change to different alignment. Values will represented in the active alignment 20251216-1311-19.5699636.mp4 Link to comment Share on other sites More sharing options...
