Hi, I have written thousands of lines and hundreds of libraries in python to customize and automate processes and now I need to protect or rather, hide / encrypt my lines, so as not to give everything away to third parties. Is there a way to make this possible on the machine, so that everything continues to work but without making visible the work I have developed?
Thanks
Antonio
https://qualityforum.zeiss.com/topic/254-protect-or-hide-scripts/
I got a complain about protection of scripts in 2020 version maybe could be taken into account or maybe you already have a solution.
- if the script is protected BUT the script runs into an unexpected error, the error is reported without any kind of filter so that the final user could get a message like:
"Error in line 241: no file in "C:\MySecretHiddenFolder\MySupersecretParametersFile.txt"
Is there a way to protect also the error messages (of course error handling would be the optimum solution, but sometimes the error hadn't been taken into account as a possible situation)?
https://qualityforum.zeiss.com/topic/254-protect-or-hide-scripts/#findComment-771
Hi Davide,
I forwarded this feedback to the responsible department but got no feedback yet.
And yes: Scripting is programming and serious programming cares for "error handling" (this is also in our daily work as developers a lot of amount of time to think and to care for wrong input parameters).
Regards
https://qualityforum.zeiss.com/topic/254-protect-or-hide-scripts/#findComment-772
Hi,
no, error messages can only be hidden 'programmatically'. Maybe you could just wrap your entire solution into a try/except block raising the exception by default, which you disable just before the release ? And it is really necessary to hide error messages, too ? You will strip yourself from the ability to react to errors happening at customer sites.
Regards,
Frank
https://qualityforum.zeiss.com/topic/254-protect-or-hide-scripts/#findComment-784
  • 1 month later...
