[Ri...] Posted December 16, 2025 Share Posted December 16, 2025 I thought I posted once on this, my Planner seat won't produce table files. Butt weight! Theres more! Only in some programs. They all use the same PCM strings for file naming and save location. Example for chr files. "V:\CMM Data Files\Table Files"+"\"+getRecordHead("drawingno")+"\"+getRecordHead("order")+"\"+getRecordHead("dmesn")+"\"+getRecordHead("planid")+"_"+getRecordHead("partnbinc")+"_"+getRecordHead("date")+"_"+getRecordHead("time")+"_"+"chr.txt" I can't explain this; it is like at random a program will not create the text files. Butt Weight Again! There's more! They all run fine on a live CMM. It is easy to tell when this happens, the Excel file will be blank. At one time while running a program that was creating blank Excel files, I thought I noticed the text files pop into the Results folder and instantly disappear before Excel was able to find them (Using Calypso excel file option). I was unable to find these files in the Recycle Bin. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 16, 2025 Author Share Posted December 16, 2025 I have in fact, watched the table files populate in the Results folder and then disappear. The Results folder is on a local drive (C:), they are not ending up in the Recycle Bin. They just disappear prior to Excel macros (Calypso default Excel macros) get to process data. Link to comment Share on other sites More sharing options...
[Wo...] Posted December 17, 2025 Share Posted December 17, 2025 I have the same issue. Simulation only. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 18, 2025 Author Share Posted December 18, 2025 (edited) I have found as I work thru the day, I will get latency issues from our network that affects the PC performance as well, it is during these times where I can visually see the tables files appear, and almost immediately, disappear. I should have included in my initial post, Calypso Version 7.4.2403 (07.10.2024) - Patch version. Prior to an update and or patch, I did not have this problem. Edited December 18, 2025 Link to comment Share on other sites More sharing options...
