possible to set nominal tolerance by condition in pcm?
Hi together,
is there a way to set nominal tolerance by condition?
this is my current script
selectCase getRecordHead("u_auft")
	case "A"
		setRecordHead("drawingno", "11111")
		setRecordHead("u_drawingindex", "A")
		setRecordHead("u_Aindex", "01")
	case "B"
		setRecordHead("drawingno", "22222")
		setRecordHead("u_drawingindex", "B")
		setRecordHead("u_Aindex", "02")
	case "C"
		setRecordHead("drawingno", "33333")
		setRecordHead("u_drawingindex", "C")
		setRecordHead("u_Aindex", "03")
	caseElse
		message("Auftrag [", getRecordHead("u_auft"), "] nicht bekannt!", chr(13),"Programm wird abgebrochen!")
		cncBreak()
endSelect
reading tolerance value works great
display(getNominal("Feature").tolerance.upperTolerance)
(Wish) would be cool, if something like this would be possible
getNominal("Feature").tolerance.upperTolerance) = 0.15
  • 3 weeks later...
The usual limit value is entered in the Lower and Upper Tol. fields.
Your reply sounds, i can set a variable in this fields or switch the fields to something.
Could you tell me how to edit this?
