[Da...] Posted December 17, 2025 Share Posted December 17, 2025 I have read many times that using a tapped hole location gage is better than trying to scan the thread with the probe. Management approved us to get one or two per month and want me to determine which sizes are the highest need. But before I do all that, I am curious: Do you use them at your facility? Do you find them helpful? How many of each do you need? I see there are sets with 2 of each but what if a part has more than 2 of that size? Do I need a gage for each hole or can I do a programmable stop and prompt to move the gage the next hole? (seems risky in case the part gets moved but buying a bunch of each size gage would be very expensive) Link to comment Share on other sites More sharing options...
[Ri...] Posted December 17, 2025 Share Posted December 17, 2025 Unless you are using flex-plugs, just know that you measuring a projection of the thread to the surface that you are mounted on. We typically do not use thread plugs unless there are specific requirements. One thing that would drive us to use thread plugs would be if there is the need to measure the thread severely projected above the surface, and the measured cylinder isn't long to begin with. Link to comment Share on other sites More sharing options...
[DW...] Posted December 17, 2025 Share Posted December 17, 2025 Please sign in to view this quote. Please sign in to view this username. Unless your facility only makes/checks a certain size threaded hole, having multiples of location plugs for most common sizes would be insanely expensive. Link to comment Share on other sites More sharing options...
[Da...] Posted December 17, 2025 Author Share Posted December 17, 2025 Please sign in to view this quote. We make MANY sized threads, so that is why I am curious how other people do it because it would end up being ALOT if we needed one for each hole on each part. Link to comment Share on other sites More sharing options...
[Ma...] Posted December 18, 2025 Share Posted December 18, 2025 I would say - if you are working with tight tolerances and/or you are having troubles with evaluation of TP/axis then it's good to use flex-plugs as Please sign in to view this username. mentioned. Otherwise find a method which suits your needs. You can also buy one set just to test how your strategy is matching plug strategy. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted December 18, 2025 Share Posted December 18, 2025 (edited) I have found through testing that typical thread Plugs (Levasa and or Tru-Pos) can affect repeatability when installing and removing/installing and removing, etc. I also found depending on the thread pitch diameter (If it is above nominal) and the thread purposely not perpendicular (Minimally out of perpendicular), you can get an invalid projection to the surface that would be in tolerance. This normally happens because a user will "tighten" (The three finger monkey grip) the gage to mate to the surface when the gage should be basically, finger snug. Flex gages were more superior in repeating and location but still can be affected by perpendicularity (See above for tightening). These types of gages can also cause minor damage to flank angles which could lead to rejections. You should examine the gage at leading and trailing edges where the splits are for buildup, especially with aluminum, magnesium and titanium, any soft material products. I personally do not use any of these types of gages anymore. It is my belief that scanning is superior for size and or location. Edited December 18, 2025 2 Link to comment Share on other sites More sharing options...
[Ch...] Posted December 18, 2025 Share Posted December 18, 2025 We use somme from them tu drill the part on it an use it foe clambuíng. We mesure with Helix path wit enough points and filter. We had one customer who prescribed that for us. Automotiv😎 Link to comment Share on other sites More sharing options...
[Ke...] Posted December 18, 2025 Share Posted December 18, 2025 I use them often. M8 through M20 for machined parts & M4 - M6 for stamped parts. I have not had any repeatability issues using solid or flex plugs (of course, I am the only person running parts on the CMM, so that's one less variable). I use programmable stops without issue (as you noted, make sure that your fixture is solid & use care when inserting them, so that the part does not move). Our prints are ASME, so the position applies to the thread pitch (not the minor diameter, unless it is stated on the print). I'll also note that I do not use the on anything that is high volume (mostly prototype work), so I do not send them out for calibration, and treat them as disposable items (wear could be as much of a factor as buildup, depending on the application) 1 Link to comment Share on other sites More sharing options...
[Cl...] Posted December 18, 2025 Share Posted December 18, 2025 I've passed type-2 Gauge R&R's (<10%) for position of threads without the use of flex plugs. I use 4-5 (slow) linear scans. High point density and a large stylus. Evaluating with Maximum Inscribed Element for ID's and Maximum Circumscribed Element for OD's 4 Link to comment Share on other sites More sharing options...
[Pa...] Posted December 28, 2025 Share Posted December 28, 2025 We have drawers full of various configurations of thread locators. I mean hundreds. I've stopped using them. They cost time at the machine. I have no trouble with direct scanning. The plugs are doing a nice job of keeping those drawers from floating away though. 1 Link to comment Share on other sites More sharing options...
[Jo...] Posted January 6 Share Posted January 6 Please sign in to view this quote. This has been our experience as well. Plug gauges have too much operator variance. (Even the very $$$ ones) Link to comment Share on other sites More sharing options...
[Ch...] Posted January 6 Share Posted January 6 Going back to the OP's question, using programmable stops are fine to remove plugs, but as you alluded to, you want to make sure there is no possibility of part movement during removal. Good fixtures help this. Here is another tip, put your programable stop at the end of the program and minimize the number of features measured after plug removal. Also, train your operators that if features that are measured after removal fail, then they need to suspect part movement. I'll pontificate some more. We both measure on threads and use position plugs. For us, it really depends on what measurement correlation agreement we have with our supplier. I've put tons of work in working with our supply chain to make sure they are using the same measurement strategies as us. But I have to me mindful of their measurement capabilities. Scanning threads won't work if they don't have a scanning cmm. Some things to keep in mind. Flex plugs are nice but your measurement cylinder is a fair distance away from the true threads. What out for projection error on these Standard plugs, like the Tru-Pos from Kremer Precision are nice; less projection error potential. But be careful when threads are on a casted surface. This is where the surface can cock the plug a little bit and cause issues. Its best to use these plugs on a nice machined surface. If doing a gage study on plugged threaded features, make sure your operator removes and reinstalls the plug between each run. Even consider using different plugs for each run. I also tell them to try and vary the amount of hand pressure they tighten the plug with. This will account for the full range of measurement error that could be caused by the plug. Consider serializing your plugs with a fiber laser if you have one. Then I also recommend doing some 5S with the plugs. We 3d print cases that only hold the plugs we have. I can tell you from experience that the Big 3 automotive companies really don't like when you send parts with cmm plugs to them. I've posted this several times on here but some of the youngins might not have it. Its a good slide deck about measuring on threads. Threaded_Holes_metrology_conf_2011.pdf 1 Link to comment Share on other sites More sharing options...
[Ow...] Posted January 6 Share Posted January 6 Boy do I miss those LuncheoN Learn conferences. On-line learning will never replace them. Threaded_Holes_metrology conf 2011.pdf 2 Link to comment Share on other sites More sharing options...
