[Zo...] Posted December 18, 2025 Share Posted December 18, 2025 i am trying to use some predefined values from Run in my piweb report but i cant access them below are what i have so far variable exist in pre-defined list but i can do nothing in this window, no option for mapping selected in header parameter input value in run parameter when i go to piweb it doesn't recall it shows value as "null" Link to comment Share on other sites More sharing options...
[Ma...] Posted December 18, 2025 Share Posted December 18, 2025 To see it in PiWeb editor you would need to have at least one measurement with this header. You should be able to see what data was stored in measurement. If this is not working, then you can map your headers into K fields Link to comment Share on other sites More sharing options...
