[Ch...] Posted December 19, 2025 Share Posted December 19, 2025 I need to change the output path in each Calypso plan we have. This is the Piweb path for all the Calypso PDF files created after run. Currently the only method I know is to open each plan individually, make a change and save. Is there a external macro or file I can modify to make this change in Calypso? Link to comment Share on other sites More sharing options...
[Da...] Posted December 19, 2025 Share Posted December 19, 2025 I use Notepad++ search/replace. Look for #pdfFilePiWebReporting in the inspset file. I hope this helps. 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted December 19, 2025 Author Share Posted December 19, 2025 Thank you. I will run a test to see if it works. Link to comment Share on other sites More sharing options...
[Ch...] Posted 7 hours ago Author Share Posted 7 hours ago This works. Thank you. Link to comment Share on other sites More sharing options...
