[Re...] Posted December 22, 2025 Share Posted December 22, 2025 Hallo zusammen, wie seht ihr das? 1.Ich habe ein Bauteil und mache an diesem Bauteil die Ausrichtung nach den Messelementen und erstelle das Basissystem 2.An dem gleichen Bauteil mache ich eine RPS Ausrichtung. Welche Ausrichtung ist nach eurer Meinung stabiler? Ich Frage, da ich selbst mit RPS Ausrichtung zu wenig Erfahrung habe. Danke Link to comment https://qualityforum.zeiss.com/topic/25429-basisausrichtungmesselemente-rps-ausrichtung/ Share on other sites More sharing options...
[Ma...] Posted December 22, 2025 Share Posted December 22, 2025 Well it depends on your features and a drawing. If you customer want's to evaluate against RPS, then use RPS. Base system is not following ISO/ASME rules of making alignment, so don't rely on it. It's good to have a good, big and reliable base alignment, but it's just for locating measured features. You will see it if you had a long or warped part. RPS is literally using about 6 points which are taking all freedom - so in this way you are good to go. 1 Link to comment https://qualityforum.zeiss.com/topic/25429-basisausrichtungmesselemente-rps-ausrichtung/#findComment-143933 Share on other sites More sharing options...
[Lu...] Posted December 23, 2025 Share Posted December 23, 2025 It's depends how precise your element strategy is are and what are your RPS and how are they distributed Plane / Line / Point is a general idea of setting up the alignment and it's correct as long as it matches the drawing If your results aren't repeatable enough, you might want to try iterative alignment 1 Link to comment https://qualityforum.zeiss.com/topic/25429-basisausrichtungmesselemente-rps-ausrichtung/#findComment-143999 Share on other sites More sharing options...
