[Kr...] Posted December 23, 2025 Share Posted December 23, 2025 Hello, I am unable to generate an Excel report from ZEISS CALYPSO using the characteristic template. My goal is to combine multiple report datasets into a single Excel sheet, similar to process study data. The report only displays the header information (Measurement Plan, Date, Drawing No., Part No., etc.), but the characteristic results (Actual, Nominal, Tolerance, Deviation) are missing. Could this be related to the template configuration? Kindly advise if any settings or steps need to be corrected to include the characteristic results. Thank you in advance for your support. Link to comment https://qualityforum.zeiss.com/topic/25439-excel-report-not-generating-using-characteristic-template/ Share on other sites More sharing options...
[DW...] Posted December 29, 2025 Share Posted December 29, 2025 (edited) Please sign in to view this username. Did you select the Characteristics.xlt when setting up your Excel output? If you want to compile many Calypso XLS files into one easy to copy and paste XLSX block, use the following PowerShell script to do that instead of trying to do anything with the Zeiss macro enabled template. It is important to note the naming convention of your files (with incremental part number) needs to be something like _001, _002, _003...._010, _011, _012 etc so when the script sorts by ascending, you don't get file names sorted like _1, _10, _2, _3, etc. This is a PowerShell script that once you give it the path to your folder containing the XLS files, it manipulates them with the final result being a file called "compiledExcel.xlsx" located in the same folder. Copy and paste the block of data into whatever official report you have, and that's it. Massive amounts of data compiled quickly and accurately. This script can be further refined, but the heavy lifting is here. <# .SYNOPSIS Converts .xls to .xlsx, trims specified ranges, and compiles data into a master Excel file. #> param( [Parameter(Mandatory = $false)] [string]$Directory = "C:\PATH TO YOUR FILES" ) # --- Helper: Logging function --- function Write-Log { param([string]$Message, [string]$Level = "INFO") $timestamp = (Get-Date).ToString("yyyy-MM-dd HH:mm:ss") Write-Host "[$timestamp][$Level] $Message" } # --- Verify directory --- if (-not (Test-Path $Directory)) { Write-Error "Directory not found: $Directory" exit 1 } Write-Log "Processing files in directory: $Directory" # --- Start Excel safely --- try { $excel = New-Object -ComObject Excel.Application $excel.Visible = $false $excel.DisplayAlerts = $false $excel.AutomationSecurity = 3 # Disable macros Write-Log "Excel instance started successfully." } catch { Write-Error "Failed to start Excel COM object. Ensure Excel is installed. $_" exit 1 } # --- Function: Safely close and release COM object --- function Release-ComObject { param($obj) if ($null -ne $obj) { [void][System.Runtime.InteropServices.Marshal]::ReleaseComObject($obj) Remove-Variable obj -ErrorAction SilentlyContinue } } # --- Convert .xls to .xlsx --- Write-Log "Converting .xls files to .xlsx..." Get-ChildItem -Path $Directory -Filter "*.xls" -ErrorAction SilentlyContinue | ForEach-Object { $xlsFile = $_.FullName $newFileName = [System.IO.Path]::ChangeExtension($xlsFile, ".xlsx") try { Write-Log "Converting $xlsFile..." $workbook = $excel.Workbooks.Open($xlsFile) $workbook.SaveAs($newFileName, [Microsoft.Office.Interop.Excel.XlFileFormat]::xlOpenXMLWorkbook) $workbook.Close($false) Write-Log "Converted: $xlsFile ? $newFileName" # Uncomment next line to delete original # Remove-Item $xlsFile -Force } catch { Write-Warning "Failed to convert $xlsFile $($_)" } finally { if ($null -ne $workbook) { Release-ComObject -obj $workbook } } } # --- Process .xlsx files (remove A1:H13) --- Write-Log "Trimming range A1:H13 from all .xlsx files..." Get-ChildItem -Path $Directory -Filter "*.xlsx" -ErrorAction SilentlyContinue | ForEach-Object { $xlsxFile = $_.FullName try { Write-Log "Processing $xlsxFile..." $workbook = $excel.Workbooks.Open($xlsxFile) $worksheet = $workbook.Sheets.Item(1) $worksheet.Range("A1:H13").Delete() $workbook.Save() Write-Log "Trimmed file: $xlsxFile" } catch { Write-Warning "Error processing file $xlsxFile $_" } finally { if ($null -ne $workbook) { $workbook.Close($false) Release-ComObject -obj $workbook } } } # --- Compile into one Excel file --- Write-Log "Compiling data into master file..." $destinationExcelFilePath = Join-Path $Directory "compiledExcel.xlsx" if (Test-Path $destinationExcelFilePath) { Remove-Item $destinationExcelFilePath -Force -ErrorAction SilentlyContinue Write-Log "Removed existing compiledExcel.xlsx" } try { $destinationWorkbook = $excel.Workbooks.Add() $destinationWorksheet = $destinationWorkbook.Sheets.Item(1) $columnIndex = 1 Get-ChildItem -Path $Directory -Filter "*.xlsx" | Sort-Object Name | ForEach-Object { $sourcePath = $_.FullName try { Write-Log "Copying data from $sourcePath" $sourceWorkbook = $excel.Workbooks.Open($sourcePath) $sourceWorksheet = $sourceWorkbook.Sheets.Item(1) $sourceValues = $sourceWorksheet.Range("B1:B1000").Value2 if ($sourceValues) { $destinationWorksheet.Cells.Item(1, $columnIndex).Resize(1000, 1).Value2 = $sourceValues Write-Log "Copied column $columnIndex from $sourcePath" $columnIndex++ } else { Write-Warning "No data found in B1:B1000 for $sourcePath" } } catch { Write-Warning "Error reading from $sourcePath $_" } finally { if ($null -ne $sourceWorkbook) { $sourceWorkbook.Close($false) Release-ComObject -obj $sourceWorkbook } } } $destinationWorkbook.SaveAs($destinationExcelFilePath) Write-Log "Compiled workbook saved to $destinationExcelFilePath" } catch { Write-Error "Error compiling Excel files: $_" } finally { if ($null -ne $destinationWorkbook) { $destinationWorkbook.Close($true) Release-ComObject -obj $destinationWorkbook } } # --- Cleanup Excel --- Write-Log "Cleaning up Excel COM objects..." try { $excel.Quit() Release-ComObject -obj $excel [System.GC]::Collect() [System.GC]::WaitForPendingFinalizers() Write-Log "Excel closed and resources released." } catch { Write-Warning "Error during Excel cleanup: $_" } Write-Log "Script completed successfully." Edited December 29, 2025 Link to comment https://qualityforum.zeiss.com/topic/25439-excel-report-not-generating-using-characteristic-template/#findComment-144035 Share on other sites More sharing options...
[Kr...] Posted January 14 Author Share Posted January 14 Thank you for your valuable information. Let me try this Link to comment https://qualityforum.zeiss.com/topic/25439-excel-report-not-generating-using-characteristic-template/#findComment-144567 Share on other sites More sharing options...
[Ri...] Posted January 16 Share Posted January 16 (edited) I had this issue before, I found I was not saving table files, if the xlt can't find the table files you don't get the data filled in. In my case I was missing the Characteristic table file, which means no Actuals, Nominals, Upper Tol or Lower Tol, Deviation (in some cases Exceed). Edited January 16 2 Link to comment https://qualityforum.zeiss.com/topic/25439-excel-report-not-generating-using-characteristic-template/#findComment-144771 Share on other sites More sharing options...
[An...] Posted February 20 Share Posted February 20 In regards to Richards post, sometimes a third party SPC software eats the table file before the Excel has a chance to pull the information. Might be a spot to look into. Make sure macros are enabled for the ini file too if you are getting any errors in regards to the ini file. 1 Link to comment https://qualityforum.zeiss.com/topic/25439-excel-report-not-generating-using-characteristic-template/#findComment-146481 Share on other sites More sharing options...
