GD&T on a scanned surface
I have the free version of Inspect.  I need to measure flatness, parallelism and perpendicularity on a part.   Are there any videos on this?  What I'm getting in the software is off from the real world.
Thanks I watched that video.   How do you enable the color deviation? We are trying to get a flatness measurement but it shows up as .002 in the deviation when creating the fit plane then .012 when we create a GD&T check.
Select your callout ( i usually select it with mouse exactly that line in flag ) - press TAB key to open side - go to Display section and you will find it there.
I also unchecking "fill" on element to see it clearly.
