[To...] Posted December 31, 2025 Share Posted December 31, 2025 Hi all, I'm new to Calypso software and I'm running 3 CMMs with 2025 software. On one of the CMMs, when I pull up my picture of the part set up, it pulls up in paint rather than jpeg. It only happens on 1 of the 3. I don't know why but that's what is happening. Is there a setting somewhere within calypso software that is not set? Thanks for any suggestions Link to comment Share on other sites More sharing options...
[Th...] Posted December 31, 2025 Share Posted December 31, 2025 That file type is probably associated with Paint on that PC. Just set it back to the normal picture application. Link to comment Share on other sites More sharing options...
[DW...] Posted December 31, 2025 Share Posted December 31, 2025 Please sign in to view this username. Go to the file location of your image. Right click the image, go down to properties. In the window that opens, you will see "Type of File:" and directly underneath that "Opens with:". Click the Change button, and select the preferred app (Microsoft Photos App?). Link to comment Share on other sites More sharing options...
[To...] Posted December 31, 2025 Author Share Posted December 31, 2025 Thank you much... Link to comment Share on other sites More sharing options...
[Je...] Posted December 31, 2025 Share Posted December 31, 2025 Hi Please sign in to view this username. The solution to your issue is a setting in windows, not Calypso. To fix this: Go to the computer you mentioned that opens the image in Paint. Right click on any image file that has the same extension as the one you use for part setup instructions (usually this is either a .jpg or .png file). Then, click the "change" button to assign a different default app. Link to comment Share on other sites More sharing options...
[To...] Posted January 2 Author Share Posted January 2 Thanks Jeff, we just installed the 2025 version and we are trying to workout the bugs. 1 Link to comment Share on other sites More sharing options...
