[Da...] Posted January 2 Share Posted January 2 Hi all, Why does even the latest Calypso calibration still suck? Why is there no option like “Mark Used” in PC-DMIS? Is there any quick and easy way to create a calibration program instead of going through each feature to check which probe it uses? Even then, we still have to manually input the formula to check the sigma and the radius. Finally, is it possible to create a single combined program that calibrates all the styli used across all programs? Link to comment Share on other sites More sharing options...
[Ma...] Posted January 2 Share Posted January 2 You can only make your program to calibrate selected probes - you can make program for every probe you have, which would be wise , to have all probes calibrated at same time. There is no way to get list of probes used in all programs. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 5 Share Posted January 5 Try this. I do not recall who made the Excel macro program. Determine probe configuration of several test plans.xlsm 1 Link to comment Share on other sites More sharing options...
[Da...] Posted January 7 Author Share Posted January 7 Please sign in to view this quote. This is very clever thank you, but again why Calypso cannot implement something like that themselves ?Shame. Link to comment Share on other sites More sharing options...
[Cl...] Posted January 7 Share Posted January 7 (edited) Everything is a la carte'. It might be an option someday, but at an additional cost Edited January 7 Link to comment Share on other sites More sharing options...
[Da...] Posted January 7 Author Share Posted January 7 Unfortunately if you are using the RDS system, this macro isn't working as Calypso does not save the probe names in the program folder. It only uses a binary information so when you open the program it grabs a data from the master stylus database. Link to comment Share on other sites More sharing options...
[Da...] Posted January 7 Author Share Posted January 7 Just come up with some idea. So what you could do is to output the stylus data in the multiple output menu and then use either chat gpt or the excel macro to combine and create one table with list of all of your probes. Link to comment Share on other sites More sharing options...
[Cl...] Posted January 8 Share Posted January 8 We run production and usually know what's being made day to day. All of our CMM programs are ran through autorun. We might run a number of over a 100 different CMM programs a day. That number can change day to day depending on customer orders. So, I created a stylus qualification program that qualifies all styli positions. for every program. I copy it as many times as I have different customer part numbers to measure. Then I edit each copy to qualify only the stylus used in a specific program, renaming it accordingly. So if I know we are running programs A, B, C, D today. I can run stylus qualification programs A, B, C, D. Eliminating the waste of running the full qualification program. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 8 Share Posted January 8 Please sign in to view this quote. Screen shot from one of my RDS programs. It listed all used probes. Link to comment Share on other sites More sharing options...
[Ze...] Posted January 8 Share Posted January 8 Thanks for the upload, Richard. 🙂 Link to comment Share on other sites More sharing options...
[Da...] Posted January 14 Author Share Posted January 14 I use Calypso 2023, maybe it does work for the older version, unless I am doing something wrong. Any tutorial please ? As far as I know the RDS probes are not saved in the inspection file. Link to comment Share on other sites More sharing options...
[No...] Posted January 15 Share Posted January 15 Please sign in to view this quote. That Excel sheet could surely use a bit of an upgrade. I didn't have time to explore the whole VBA code, but I can say it only looks for the sections "usedProbeConfigs" in inspset and "probeConfiguration" in inspection. What it doesn't look for is "holderId", which is used in probe calibrations. I found an old calibration program where "usedProbeConfigs" is empty. So in a program like this it wouldn't find any probes. I can say nothing about RDS probes though, since we don't use it and I have no example programs availabe. 1 Link to comment Share on other sites More sharing options...
[Da...] Posted January 21 Author Share Posted January 21 Does anybody have any updated version of this excel ? I do not know why it's not working, but I think I was wrong and there is a 'probeconfiguration' and the stylus data in the inspection file so it should work. Link to comment Share on other sites More sharing options...
